1 - 9 of 9 Posts
Hello, I'm in the process of building an LT1 for a project of mine, and during disassembly I found that the #6 and #8 rods are slightly bent.
200355
I'm not sure why they're bent, the rest of the engine looks perfect, the bearings, cylinders, ect. Although the rings on #6 and #8 are slightly more worn.
Anywho, can I just remove the rods from the LT1 pistons, and install ones from the 78' 305 I have out of the project car?
Slightly bent is when checking the rod to piston alignment shows something.
Those are more like BENT .
Typically there is a tide line ( or the classic rammit ) associated with rods like that!
Can't comment on rod weight. Early LT1 ? Forged Rods , not from a B car?
Early rods from a 95' T/A.
Forgive my ignorance, but what's a "tide line"?
Sure.....if they're the same weight and the same length.
KW
Do you need some stock rods? I have some with pistons that I am willing to part with.
I have 6 that are complete
2 are missing the rod cap and one piston looks new.
I believe that these are stock LT1 pistons and rods from a f-body. I would need to take measurements make sure.
Where are you located?
200440
200441
200442
Looks like these are stock LT1 pistons. Mahle 101ST7
200445
The rods do not have any markings or identifiers, so I am assuming the rods are stock as well.
Please let me know if you are interested.
Michael
Discussion Starter · #9 ·
Problem solved, I just got some more pistons/ rods. Someone on the Ebay is selling a bunch of LT1 pistons and rods, so I got a #6 and #8 to replace my bent one. They look exactly the same ( but not bent) as the ones they're replacing.
Body jewelry Material property Silver Jewellery Gas
Household hardware Gas Nickel Nut Metal
1 - 9 of 9 Posts
