Does any rear bar give near neutral cornering with the stock front bar? It seems like the Hotchkis rear bar would not be stiff enough to do this and the HA/HO bar is obviously too stiff.
Helwig also makes a rear bar. But it is about the same stiffness as Hotchkis. If you are running stock front springs, wagon rear springs will give you a more neutral setup.
Is there any way to get an SLP bar, beyond used? I don't think it would be dead neutral, but maybe like the HO/HO setup.
