Originally posted by MrCadillac (Magnum):
"street cam" seams hard to difine. But a street cam to me would: Work with 3.08-3.73(up to 4.10 with T56) gears, unported heads/3 angle valve job Stock valvejob is better than most performance shops can offer. , stock-2500 stall Better to go with a GOOD say 2800 9.5", they drive better than you think. , full weight, replacement springs w/1.6 rockers Rockers need to work with the cam most of the popular cams have too much exhaust lift to use 1.6s without valveguide mods. , no machine work needed, stock manifolds-mild headers Been there done that do headers first. , full exuast(cut outs not needed) Decent catback is all you need, cutouts are either a bandaid for a crappy catback or are for making noise. , works with power brakes without expansion chamber Not a concern unless you go stupidly big. , optimal shift at 5500-6000 I am shifting the ZZ3 cam at the top of this range the engine does go over 6K during the shift, this is the smallest cam I feel worth the effort 208/221. . thats what a street cam should do with. IMO
