1 - 13 of 13 Posts
Okay, I have given myself a brief education on sway bars and I believe that the best set ups are: F-Body(2nd Gen) FRONT and HA Sway Bar in the rear; OR HO Front Sway Bar and HA Rear... AM I RIGHT?
K
Yup... (note that the HA rear bar and the HO rear bar are basically identical).
The Setup with the HO front will tend slightly toward understeer while the F-body front setup will be dead neutral.
Where can you get an F-body bar? and what is the going price?
K
2nd generation F-body front 1.25" bar, National Parts Depot... I think it's $119 now.
D
Anyone know the price of the HO Front Bar? Can you get it from Malibu as well?
ThankSS
Eric Moore
K
Sorta, and yes, respectively...
I think it's $179 and they do sell it.
D
Thanks Knightshade, you happen to know if it comes with mounting hardware, or is it best to follow Scott M's article for install part numbers.
ThankSS
K
I have the F-bar myself from NPD so I don't know for sure... I know the rear HA/HO bar from Malibu did not come with any hardware though.
A
I bought the HO specialties front bar last year and it came with bushings,new end links
an everything to install except the bolts for
the bushing brackets. Got them from totally
stainless. Installed with blue locktite, no
problems since 20K miles. except for some
occasional popping noises at full lock when
parking or turning in to a drive way.
H
What's the handling on a f-body front and stock Impala rear bar?
Heavyevy, I had the f-body front bar on for several months waiting on the HA rear bar. When I add the f-body bar there was a very noticeable difference for the good. When I added the rear HA bar there was a difference for the good but not a much as the front. I had no problems with the f-body front and stock rear.
K
<BLOCKQUOTE>quote:</font><HR>Originally posted by Allen:
except for some
<HR></BLOCKQUOTE>
Try greasing your steering stops! Put grease on the knuckle, where it meets the frame, and on the frame tab. It might just fix the noise
Discussion Starter #13
If going one bar at a time, I'd make sure to do the F-body bar first. I would guess it would make for flatter cornering, with terminal understeer even more than stock. After that, the rear bar change would probably be most noticable when really cooking it into a corner. The back end would drift without having to pour the power on. Doing the rear bar first would result in oversteer at the limit, which could be pretty hairy in a collision avoidance manuever, to say the least.
1 - 13 of 13 Posts
