1 - 12 of 12 Posts
Someone said that they coiuld go to autozone and get Bilstein Shocks for 55$ a piece... Is this real, do i have to have a coupon, or whats the deal with this... I looked and they were 89 a peice.. any truth to this?? oh please please
K
I had the exact same finding. Screw AZ. Use shox.com, old faithful.
I think its the rears for $55 or so. The fronts are more expensive. I had them in 2 days from Shox.com . Great place from my experience.
J
u can get all 4 for $254 shipped (cheaper than shox.com) do a search for Bilstein there was a recent post about it
K
Nope - I stripped my rear lower mounting nut/stud and went into AZ to see if I could get new ones. That was when I found out about $89. I really don't understand how some find them for $55 at the same damn parts chain.
The rears are 54.95 apiece. They must have been referring to the fronts for around 90 dollars. I have a reciept for the rears so I am 100 percent positive. You must have talked to idiots if they told you 89 for the rears.
Also, make sure you're pricing the right ones. The softer ones (sorry, can't remember the numbers. 91-96) are $85 front AND rear. The boxy's are $85 fronts and $55 rears. HTH
Sean
Sean
good point...
The softer Bilsteins are #1516 +1517 Progressive travel ; The stiffer Bilsteins are # 1104 +0929 Linear travel.Somewhar more accurate to say Bilsteins can be either linear valving or degressive valving. Custom revalves are also available, but tricky.
cost wasnt a real issue, just wanted the best for the cheapest...
you know how it is.
I ended up ordering from the 259 guy on the forum.
I just bought some 0929's yesterday there now 59.99 at the big A-Z...THE BASTARDS
1 - 12 of 12 Posts
