I scored a mint 2000 blazer console for 16 bucks. Whats the scoop with these things? Drill three holes and call it good or does it require some trimming?
well, you need a mount for the shifter to mount to so it doesn't move around when you shift between gears, and you need to cut or drill a hole for your shifter cable, and you need to make sure your front seet is a bench or els the shifter wont fit. also i guess the better question would be is it the one with or without the shifter?
Sorry guys. My car is a 9C1 with the stock bucket seats. Its a floor console out of a column shifted blazer as I plan on retaining my column shifter as well.
Ovbiously the contour of the floors are different and Im just wondering if people trim them or somethin. It seems alot of people have done this mod.
