I have a 1993 Caprice and I'm really aggravated with it. When I turn my right blinker on with the lights off, both sides blink as if the emergency flashers are on, along with the speedo,climate control lights and plate light! When I turn the lights on and hit the right blinker, NOTHING blinks! Left blinkers works normal with lights on and off! I have no led bulbs in the car, and have replaced both blinker relays.
Roll up your sleeves
Could be a Grounding problem.
You will have to check several locations:
Harness to speedometer/gauges
Rear right brake socket
Front right turn signal socket
Signal swicht damaged
Your problem is at teering wheel column. The signal swicht has a mechanicalbad function and need to be replaced
