Will the BMR sway bars work fine on my Caprice. It has the drums on the back, so I think the rear end is shorter. Does that matter? Anything else that I need to go with them?
OutKaSSt,
Rearend width does not matter, the bars attach to the lower control arms (same on all models). You WILL need to replace the lower control arms because aftermarket sway bars will turn them into pretzels. So while you are ordering your BMR sway bars get a set of their lower control arms(about 160 bucks). There are other brands of lower control arms, but BMR seems to be the best for a low cost solution.
JP
<BLOCKQUOTE>quote:</font><HR>Originally posted by jpalmer:
OutKaSSt,
<HR></BLOCKQUOTE>
Except wagons, they're wider.
