There is zero need for extended arms on a wagon. If you're on tall sidewall 275 60 15s, stick with arms that have regular bushings.
Oohh... now that looks interesting. In all my research, I never once came across the name "SpeedTech". They've got some really great-looking productsI went with the SpeedTech setup
Are you running Rubicon joints at the axle end of the UCAs? Is this with custom arms or OEM stamped steel ones? I was trying to visualize how to use a Johnny joint type of end up there, and couldn't figure out how the arms would accommodate that without hitting the bushing ears on the axle short of widening the UCAMy car has six 3 inch Rubicons and two Jonny joints.
It really is not harsh or noisy at all.
While the male female thread speedtech
deal with bind during chassis roll, I fail to see how they will deal with the upper arms , set at roughly 90 degs to each other.
With no roll , just vertical movement the upper arms run in completly different arcs putting a bending, not rotating force in the arms.
The roto joints or my Rubicons with their huge wear surface , compliance, and adjustability are nothing like conventional rod ends or spherical bearings.
While not that I would run rod ends in a street driver, in their defense, good joints eclipse the cost of arms on the market so I really doubt the retail offerings are getting the top shelf joints.
Case in point , one 3/4 NMB
(ARHT12ECR) NHBB 3/4 x 7/8 RH $161.00
Oh I have some cast stainless tubing that has 1/4" walls and a 1-1/8" ID that would be perfect for this. Just need to thread the inside to 1 1/4-12 and use a long nut to lock the joint in place. If I do that at both ends with LH and RH threads, I can even make them on-car adjustable.You might want the use "tube" and weld ends
That's perfect! I may not even need any spacers 😁EDIT 2.65"
I've pretty much given up on the idea of an OEM-style swaybar. There's so many frame-mounted options available out there for far lower prices and a lot less compromise.Also, round lower arms pretty much stops you from mounting a production style rear bar .
Dude I love those, they look promising. Decent price, too. Especially if the parts to rebuild them remain available for a few years.Looks like Ballistic has upped their game since I delt with them .
Might be an option again
