·Hi,
What's the difference between SS and 9C1 upper body bushings? Harder rubber? wider? I would prefer a slightly stiffer bushing than the stock SS ones and am looking for confirmation.
Also, do the 9c1 or SS upper bushings still come with the metal spacer or do we need to order separately?
I have the frame off the car and plan on replacing upper/lower bushings and some of the rotted metal spacers. I did buy an Energy Suspension 4136 kit but in doing a lot of reading on this site most people don't recommend it. Fine, back it goes.
Now in reading a lot of threads on the bushings some people are actually recommending the 9c1 as being the better ride, firmer than the SS (which is what I want but not as hard as the ES)? Comments please.
I do plan on using the Mueller lower bushings and already replaced any of the body bolts that were worn out.
Following are the P/N for the pieces. I have both 9c1 and SS down. I need to order this asap so I can get the frame back on.
Thank You for any assistance.
Impala SS upper body mounts:
3524486 Upper Body Bushings (Pos 1,2,4,6)
10201228 Upper Body Bushings (Pos 3)
556755 Upper Body Bushings (Pos 5)
330992 Upper Body Bushings (Pos 7)
7B3/9C1 upper body mounts:
348080 Positions 1 & 3
330986 Position 2
330942 Positions 4, 6, & 7
488610 Position 5
Both 9C1/SS lower mounts (Mueller Mod):
457915 Position 1,2,3,4,6 (Pink) lower mounts
457917 position 7 (Dk Green) lower mounts
Both 9C1/SS lower mounts (GM OEM):
377801
Bolts (note: Position 5 has no bolt):
Impala SS:
3524497 All positions except #3
3528567 Position # 3 (shorter bolt by 0.400)
9C1:
3524497 all positions except 3
14085301 for #3 position only (shorter by 0.400)
Metal Spacer (reuse for aftermarket or you get with upper kits?):
6262234 for all positions
[ 06-28-2007, 12:54 PM: Message edited by: Gary Gevaert ]
330986 Position 2
488610 Position 5
377801
Impala SS:
9C1:
