Anybody ever remove some of the wood vinyl on a corner of a door or other area to fix body work (weld and paint) and then put it back? Can that be done or do you have to get a whole new piece. How well would a new piece match?
Originally posted by Ruphrax:
Depends - what happened? What are you trying to fix?
Remember the black rubber gasket around the drivers door lock hole? The sheet metal under it is cracked and I need to get it fixed so it doesn't rust. Also when I was trying out a new key I had made that wasn't working so well the lock cylinder started pulling out from the door. It is a paint to lock and unlock with a key without the lock rocking around. Just wondering the best way to fix it.
