is there any simple way...?
cats meet the manifold, right next to the block, i tried getting under the car with a breaker bar and i broke my ententionWhich ones? ones where the cat pipes meet the catback? Or the cat pipes meet the manifolds? or the manifolds meet the head?
Liberal amounts of liquid wrench. Let soak for at least a day and reapply. Turn on the car and get them hot if necessary. Use a good quality extension. You'll be putting a lot of torque on it when breaking them. Last resort would be a torch. Replace w/ stainless bolts/washers/nuts and anti-sieze. You won't have the problem ever again (unless you DON'T use anti-sieze!).cats meet the manifold, right next to the block, i tried getting under the car with a breaker bar and i broke my entention![]()
saving up for air tools atm...In addition to the tips that SEO9C1 listed, an impact wrench is a huge help in breaking loose corroded exhaust fasteners.
Have you considered a cordless to hold you over till you have your dollars saved up?saving up for air tools atm...
wish i had them already
wow never knew... good stuffHave you considered a cordless to hold you over till you have your dollars saved up?
This one is cheap, but only makes 140 Ft. lbs.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94855
This one is more expensive, but makes 220 Ft. lbs.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=65817
For reference, stock B-body lug nuts are supposed to be torqued to 100 ft. lbs. I've been using the same Harbor Frieght cordless impact since 2004 and use it often. I race (swap tires) 8 or more times each year, plus stuff around the garage. I hardly ever drag out the pneumatic one unless this one can't break it loose (almost never). It is the best money I've ever spent on an automotive tool.
Harbor Frieght also sells cheap impact sockets. They may be cheap, but I've never broken one.
we soaked bolts in the liquid wrench already, but motor is in pieces so starting is not an optionLiberal amounts of liquid wrench. Let soak for at least a day and reapply. Turn on the car and get them hot if necessary. Use a good quality extension. You'll be putting a lot of torque on it when breaking them. Last resort would be a torch. Replace w/ stainless bolts/washers/nuts and anti-sieze. You won't have the problem ever again (unless you DON'T use anti-sieze!).
hmm that is good, wolf Im gonna have to get a floor jack to lift that car higher, that little one a aint cuttin itHave you considered a cordless to hold you over till you have your dollars saved up?
Not always true. I have taken them off many times on my DCM Roadmaster. An impact does wonders, because it gives the studs a repeated shock, which helps break them loose. If you just stick a rachet on there, put a pipe on it, and crank down.. then ya, you are more likely to snap them.If they're stock manifolds, the flange studs are just gonna snap.
naw pulling the heads, but headers may go on aswellIf they're stock manifolds, the flange studs are just gonna snap.
I hope you need to just take them off because your putting headers on...
sprayed PB on the bolts but not able to work on it til the weekend, so hopefully it will either be ready to come off or we have the right tools for the job, thanks guysAhhhh yea. OP is a cali guy, so he might have luck with PB and an impact.
Im in NY, so like you said its useless for me too lol.
