Boxing lower control arms (is there a weld kit?)
1K views 5 replies 3 participants last post by  96 Black
#1 ·
Hello, I have my rear end out for rebuild and want to change my upper and lower control arm bushings while I have room to do so as well as maybe put some chassis paint on some areas where the vehicle needs it (surface rust) where the shocks and springs sit at top. I’ve been reading about upper adjustable and lower extended control arms. I’m still deciding if I want to spend the money. I understand from some posts that upper bushings will wear from some type of binding because the geometry changes from stock forward positioning of the rear diff. Posts also believe the connections (Clevis positioning etc. can help). Idk, I want NO reason to have to change worn bushing parts up in there for a long time. Also, I want to broken parts up in there later earlier than stock parts will last. I also read that stock upper control arms may be better than aftermarket because they need to flex a bit. I know performance control arms remedy wheel hopping and lateral movement (tire rub around corners). I understand for racing purposes people want rigid suspension there but my car is not a race car. It has a stock engine with 3:73 gears in it and a cold air intake. That’s all. I’d like to have my wheels centered in the wheel well. That would be nice. I just want to weigh my options here. Should I put extended control arms upper and lower while I’m here with the diff out?
Questions:
1. Is it a must I need to have upper adjustable control arms to use extended lowers for pinion angle? I’m guessing yes. My car is lowered 2 inches (With springs) in the rear as it sits with 24 inch rims.
2. Do they sell a weldable boxing kit like I’ve seen on Summit racing website for older cars “for our 94-96 Impala and Caprices?“ has anyone boxed theirs? I have yet to find a post on the forum.
3. If I do put adjustable upper and extended lower control arms to center my wheel, whats the chances I will have “binding issues” or “chewed up rubber parts” on my uppers? That’s my fear. I dont drag race but do get some corners sometimes for fun. I don’t want to burn rubber here and there, and find I need to change these upper bushings “poly or whatever” in a couple years. I’d kind of rather box my stocks, put new bushings in Upper and lower and see many miles to come with a wheel that sits forward a little bit. As for wheel hop, I’ve experienced that too. My tire grabbed my wheel once on the lower front corner and bent it. Dont get me wrong but this Binding and rubber chewing up thing is the reason I am staying away from that decision (binding issues). Am I not seeing something clearly or am I over reacting? I want a solution that is as good or better than factory for my daily driver type semi stock street car. I feel like wheel hop and lateral movement fixes is the trade off for replacing bushing in such a hard place to get to. What’s the General fix to this Bushing bind? Has it been fixed yet? Do people run rubber vs poly? Do the control arms accept stock bushings? Is Metco a good option?
4. Do these after market upper and lower kits put more stress on the mounting tabs that are welded to the vehicle Since they are more rigid? Is it possible I could break mine in the future?
5. which bushings wear and tear on the uppers? On the diff? On the body side?
6. How long will a set of Metco upper adjustable and lower extended billet last me? They say no other mods are required. I’ve read the drive shaft does not need to be extended and read it does. Can I get some feedback on this one? Will my stock driveshaft suit me with light driving until I get the shaft? I’d probably get it don’t as soon as air get my car back on the road but will driving it to a shop break something on the tranny spline side? Does this all depend on what kit I use?
Im interested in this kit. >>>>>>>>>>>>>>1994-1996 Chevrolet Impala Parts | A657503 | 1994-96 Chevrolet Full size Models - Billet Rear Control Arm Set (0.75 Extended Length) | Classic Industries
Thanks.
#2 ·
Ed Runnion and I did some boxing of the lower control arms in the late 90's. The metal on the factory arms are just too weak. Once you box the arm it will start to rip at the top mounting point for the sway bar. You are better off investing in a solid aftermarket unit.
  • Like
Reactions: helpthe95
#3 ·
Unsure the purpose of duplicate thread, but just copying my reply to the other one. Responses bolded - Good luck.
[Quote: helpthe95]:
With my HO bar I knew I was in for at LEAST some manner of new aftermarket arms, so whatever the added difference in cost from regular to extended lenth was the upcharge to move 5/8-3/4" for visuals. Boxing the oem (detailed below) was an option, but not my preferred route. HTH
You're mixing 2 things. Keep them separate. 1.) Even the orig. uppers 'bind' as a result of torsional stress as the car corners at extreme angle. Stock softer rubber bushings yield more so this --> usually <-- isn't an issue for the life of the car. 2.) Enter (much) stiffer aftermarket stab bars that DEMAND aftermarket arms, and all the guys figure the perfect time to upgrade to 'stiffer' poly bushings all around for improved road feel and presumed less wind-up and hopping during accel. Great, but now the binding uppers becomes an issue. For those who don't require extendeds then many have learned just to get nice new stiff lowers to handle the stab bar, and don't even bother with touching the uppers.
Yes, offset clevis is intended to address and relieve torsional bind. Great feature, and any suspension upgrade is valued in light of what the car will be used for - garage queen, driver, strip, full race.....
Aha. So you caught that already. lol
Again, you've been doing your homework. Yes, harder bushings; less sideplay; less lateral slip. And it helps rubbing with big wheels/big tires.
100% up to you. But never a better time than with the rear out. Lots of combinations, *leave rubber in the axle ears or replace, *leave the uppers as-is v. new ones if not doing extendeds......
Questions:
Yes. No way to retain proper pinion angle using orig. length upper with extended lower. Not logical.
Just personal opinion, but with those big wheels the car should NEVER be cornered at a speed even close to where torsional bind of a control arm becomes an issue.
Err?? You can answer that on your own. If not showing an app for last gen, then the prior box gen used the same control arm(s). I've seen the weldable plug barstock, and there are manufacturer 'bolt-in' pieces for a stock lower too. It may have even been a TSB or assembly line add depending on suspension option.
I've seen numerous. Don't use 'Relevance' in your search. Use 'Date'. Put " " around your keywords to focus results better.
Al addressed otherwise.
[EDIT]: See SSlow94 reply above.
Addressed above.
Mine are 20 years old, 60k. Original dia. rubber, 10" widened stock wheel.
You're perfectly correct. All the debate focuses on the extent of reduced DS's spline's load bearing on the output shaft. Factors include extent of power adders, each aftermarket brand's "extension" whether 1/2", 5/8" or full "3/4" to true center.
You have nearly no power adders and you're citing 'light driving'. So the answer for me in similar conditions was "No". But, you also state you like to, "get into corners" and then there's the big wheels, and those been shown to cause increased driveline stress even on their own, so now the answer changes to "Yes". If electing to get a lengthened DS your options are something like Denny's with their great reputation, or the 'Crown Vic Composite Cop' DS, which is 3/4" longer than our stock length.
Pretty likely not. But why are you driving anything to a shop to change a DS?
Addressed above.
#5 ·
Yeah, I didnt mean to do a double post. Yesterday, the website was giving me an “oops, something went wrong“ type data overload message saying “try again later”. I guess it accepted my try again. I tried to delete one but there is no option unless I post it as a deleted post. I wasn’t sure if I should do that. Thanks for your detailed reply. It sure helps me out. I appreciate it.
#6 ·
The 'new upgraded platform' here is.... is ..... well it's a wonderful thing. Next time, 3 dots in the upper right of your post in question (not the 3 dots in the upper right of the screen), then Edit, then replace all with, "Nevermind, double thread" Brilliant!
Again, well ordered original post. Both times! All notable due to its exception to what's been 'Trending' here of late.
Hope you end up with exactly what suits you. When I was picking my suspension components it took weeks and a hundred posts on seeral old forums (even BBS) to get everything perfect the first try.
  • Like
