INDEX & 2. Making some sense out of a few brake mysteries
INDEX (click on item 3 - 15 to go directly to topic)
2. (this topic page - below Index) Making some sense out of a few brake mysteries (rear disc park brake adjustment & other info)
3. Front Caliper info & Manufacturer Brake Tech & Maintenance info
4. Front brake upgrade thread (stock diameter, 25% thicker disc, clears 15" wheels)
5. Brake Component Manufacturer Tech Bulletins
6. Power Stop brake information
7. Disc Brake Lubricants
8. REAR BRAKE UPGRADE & CONVERSION - information
9. New tech info - brake judder issues
10. more about GWR Specialty Automotive Products
11. Disc Brakes Australia information
12. 3M hub cleaner kit
13. Brake Maintenance Parts Info - Aftermarket - Calipers, brackets and hoses
14. Brake-related Vendor listings by Navy Lifer - quick reference
15. Brake lines (hoses) - some Q & A
Rear Disc Park Brake Adjustment info
94-96 Combi valve mods - Parts I, II, III - AKA "stealth bolt" (props to Ken Rolt)
Brake Pad info -- PFC, Raybestos
Honeywell Power21 parts list--just plug in your year and model, and a complete data dump of ALL brake parts will load.
ABS Sensor info
There's ALOT of brake info that has already posted in Forum, and a SEARCH for the right topic can usually get you something to work with.
__________________
Bill Harper
ISSCA #127
[email protected]
Last edited by Navy Lifer : 07-08-2009 at 08:08 AM. Reason: added Combi Valve mod info, moved index
Navy Lifer
View Public Profile
Send a private message to Navy Lifer
Visit Navy Lifer's homepage!
Find all posts by Navy Lifer
05-10-2006, 04:33 AM
Navy Lifer
Senior Member Join Date: Nov 2000
3.a Front Caliper info--a couple of many:
Thread 1 and Thread 2 (SEARCH Forum using "JA9" finds over 36 posts and lots of info)
3.b Brake Tech & Maintenance--some selected reading materials (no endorsements, just info)
see Baer Tech links for Brake Bleeding, Pad Bedding and Rotor Seasoning
StopTech technical white papers
Bendix Tech Corner
ACDelco Preventive Maintenance for Brakes
__________________
Bill Harper
ISSCA #127
[email protected]
Navy Lifer
View Public Profile
05-29-2006, 08:30 AM
Navy Lifer
4. "Front brake upgrade" thread
Direct link - HD12 front rotor upgrade and front/rear combination upgrade details in - Vendor Forum
HD12 prototype installation - in Brakes Forum
__________________
Bill Harper
ISSCA #127
[email protected]
Navy Lifer
View Public Profile
06-01-2006, 06:54 AM
Navy Lifer
Disclaimer: For information purposes only. No endorsement or validation of information disclosed here is intended or implied. Some linked items are written from a "down under" perspective and may not be applicable to North America. Some articles address issues from the service technician perspective. Intent is for all information to have some value for those reading it.
PBR Technical Bulletins
Tech Support Tips and PBR Performance FAQ
(links below are PDF format)
Rotor Fitting Tips
Disc Brake Rotor Minimum Thickness
Disc Rotor Replacement
Flushing Brake System (ie. Brake Bleeding)
NOTE: Bleeding procedure (above) may differ for LH control cars depending on master cylinder location--procedure shown here is for Australian cars with RH controls. B-body should be bled RR, LR, RF, LF in order.
PBR Banksia Park Brake
Disc Brakes Australia (DBA) Technical Presentations
(some are redundant to PBR info)
The Complete Brake Job
Disc Thickness Variation
Premature Front Pad Wear
The Importance of Observing Scrap Thickness
Ten Things Every Motorist Should Know About Brakes.....
Research & Development
Kangaroo Paw Design
Major Considerations for Race Track Use (PDF format)
__________________
Bill Harper
ISSCA #127
[email protected]
Navy Lifer
View Public Profile
08-13-2006, 10:10 PM
Navy Lifer
ABS Sensor info
__________________
Bill Harper
ISSCA #127
[email protected]
Navy Lifer
View Public Profile
Navy Lifer
Bendix Tech Corner
__________________
Bill Harper
ISSCA #127
[email protected]
Navy Lifer
View Public Profile
Navy Lifer
__________________
Bill Harper
ISSCA #127
[email protected]
Navy Lifer
View Public Profile
Navy Lifer
Rotor Fitting Tips
Kangaroo Paw Design
__________________
Bill Harper
ISSCA #127
[email protected]
Navy Lifer
View Public Profile
Navy Lifer
