what if it broke inside?
This one looks like it was broken inside. I have used this myself. The weld material does not attach to the cast iron heads. So you can hold a nut to the outside of the head and fill the inside of the nut with weld filler then turn the whole mess out. The heat of the weld actually breaks the rust bonds between the old bolt and the head. Works great.
