1 - 1 of 1 Posts
Was at the JY on Friday, seen a low mileage Fleetwood Funeral car with the same seat as my 94. I grabbed the passenger side seat
The passenger seat bolted up on the driver side with no modification at all, but the wire harness under the under the seat cushion had to be swapped other wise the recline did not work, but very easy to do, and I moved the recline switch over the the correct side also. The factory bracket swapped right over.
I had to use a Caprice seat belt on the floor, since the Fleetwood seat have the seat belt with the seat but it was on the wrong side.
I grabbed a Blazer center console to install, after a blue interior paint job this week it will be going in the car.
Took about 1 hrs to change out and get it to work correctly.
1 - 1 of 1 Posts
