My 96 9C1 is missing the build sheet under front pass seat. (Seats look pretty good for a 159,000 mile car figuring they must have gotten redone at sometime and the sheet got trashed) I had heard that some b bodies had them under the hood insulation as well as under seat. Is this true and if so is it worth the effort to check undermine or is it a big pain.
PS anyone have a Carfax account or access to run a VIS ?
The VIN# 1G1BL52P0TR144101
My E-Mail [email protected]
The SPID label on the trunk lid should tell you everything the build sheet could, as long as your trunk lid wasn't replaced or the label painted over.
Try VIN test Other than a notation about a duplicate title, there's not much to see... looks like it spent it's whole life in PA.
You can get a copy of the original invoice from Chevrolet... (mostly the same stuff as the build sheet) I got mine a while back. I have the info here someplace, I'll post it if I can find it. The SPID lable is the easiest way.
