Several years ago I picked up a pair of iron heads from a local wrecking yard. I don't know much about them other than someone wrote 96 Impala on them. No idea of mileage or why the car was scrapped. The thought was to work on them a little here and there and eventually have them ready to install on the wagon at the same time as a cam install. That plan has now changed due to a low oil pressure problem that popped up. DETAILS HERE. I'm now going to be building or rebuilding a complete engine for the wagon and need to get these heads ready to go on the new engine. I'm not in a hurry since the wagon rarely gets driven - especially in the winter - but I do want to keep it moving forward.
Why am starting with iron heads instead of aluminum? To be honest, I went back and forth a bunch of times and I'm still not convinced I made the right choice. The light weight and easy cutting of aluminum are big benefits. The iron seem to be easier and cheaper to find locally. They also have a reputation of being less picky about head gaskets and supposedly have redesigned ports that flow better.
I've done some searching to try to quantify the flow difference from the improved port design and the best I can find indicates that the aluminum heads flow 206 CFM on the intake and 161 CFM on the exhaust. The irons flow 226 CFM on the intake (which seems to match what I can find for stock Vortec intake flow). If anyone has better data, feel free to share.
What are my plans for this head build? Subject to change, but:
- I currently have the press in rocker studs pulled and I'm going to machine for screw in studs.
- I have VS2700 springs from Bullet on my shelf.
- I also have a set of Comp self aligning ultra pro mag 1.6 rockers on the shelf.
- I'll measure the clearance of the valves and install bronze guide liners as needed to bring any worn ones back to spec.
- They will get a performance valve job for sure and I'll very likely install 1.60" exhaust valves. I haven't decided if I'll go to 2.02" intake valves.
- The chambers will get work to unshroud the valves for improved flow. Unfortunately this drops the compression a bit which is opposite of the direction I want to go. So..
- I may get the decks cut slightly to bump the compression back up.
- The intake and exhaust ports will both get work to improve flow, but this part is still up in the air. I haven't decided if I'll just go into this blind and be conservative in my cutting while following the Vizard Vortec porting videos on YT - OR - if I'll build a simple floating depression flow bench so that I can measure my progress.
- I might do ceramic coatings on the chambers, ports, and valves to minimize heat transfer, but again am undecided. The before and after dyno tests with completely coated engines seem to indicate there is not a lot of bang for the buck with the coatings.
