local pick up only stuff first sorry cant ship these couple things
Clean set of SS seats factory removed from one of my 96 cars to do custom interior left these stock beautiful no rips, tears, scratches
1500.00 include the power tracks and plastic trims and bolts
set of 96 pistons and rods very heavy I cant lift these the seats or heads due to disability so
cast iron heads 67k 150 set
piston and rods 100
Stuff I will Ship
beautiful battery tray painted with por 15 gloss black with the upper and lower bolt and washer
grill emblems blue red silver
ac heat knobs multiple pairs
hood trunk light assembly and lights
fbody TB cover
AC compressor was perfect when pulled motor I replaced everything except some bolts that ARP didn't make 50
3 LT1 Throttle Bodies 50 shipped
2 F Body throttle body covers with brackets and hardware 43 shipped
air intake system 3 home plates 2 first base 2 brackets 3 elbows
10 IAT sensors
2 intakes 80 shipped eachs
EGR valve and solenoid both have 2800 miles removed and deleted no emissions here 55 shipped
oil tube and dip sticks
tranny tube and dipstick
2 sets of lt1 valve covers
timing cover this is the 95 style
IAC center
TPS sensors
oil pressure sensor
water temp sensors both the head and the one in the water pump
rear end cover
starter like new used 5 times and someone hooked me up with the vette mini starter on here
AC drain pan elbow with extended hose make sure you wont get a puddle in your pass floor
vac hose for brake booster
impala leaping deer emblems 16 pairs
rear trunk emblem sparkling red will need paint not a factory color 20
front grill emblem
blue, red chrome
pair of door locks with key 13
lower black driver side door molding front and rear also the small moldings along the bottom exterior too
95 console black upper part is faded
one jacks
5 jack handles
10 tire hook and retainer nuts
front door handle and rear plate
3 driver front arm rest
all have varous thing wrong with the clips underneath he said
text for more info
2 grey
1 gloss black
all dash vents box full of various ones
full grey ashtray assembly with rails
black sem ashtray assembly
grey headrest material pair
aux post BRASS replace if your is not brass fire hazard
aux fuse black casing ( the box no fuses)?
rear frame mount muffler hanger pair excellent shape no rubber
ALL door hinges for the car black in color one or 2 he said were sold
drive top rail weather stripping
impala grill side braces the triangular ones and hardware
2 driver side air dams
PCM top cover
AC HEAT knobs
3 sets
Impala door lights front pairs
RM rear door lights
clear and impala style lens available
MAP lights
tag light assembly
dome light assembly and lenses
ac control light harness
ash tray
ashtray change tray
ashtray light harness
sorry will have my wife or brother do it tonight they typed and showed me the parts hacve2 more bins
