Well went out tonight and tinkered a bit, got all the old brakes off, I am going to have to replace the hardlines they are shot that is for sure.
But I got the hubs and brackets from Tobin Thursday, and they are a piece of art that is for sure.
I pulled out the BRAND NEW 5/8 spindles that I was going to cut up for the mod and I just couldn't do it, they were to pretty
I put them back in the box, and they are on the maybe use later shelf. Got both of the old brake shield holes drilled and tapped as required, cleaned up the calipers as they were used, very low mileage mine you, but still used and GM pads from the factory are DUSTY bastards, The pads and pins came with the calipers, but I may not use the pads and just get new ones. Not sure yet.
I will have the front done this weekend, well prepped anyway, my CNC guy has my rotors and he is going to do all the machining to them and drill the new bolt circle for them, for um well a case a beer and a sandwich
Thought that was a pretty good deal, he was going to manually cut them, but he is going to write the program in case I need it done again.
One the front is prepped I will most likely pull the entire rearend out of my car for room, I am going to prep the lower mileage rear that I got from Mike (94MSP9C1) for use in my car as the axles in my car are shot and I would like to redo the gears in my car anyway. But I need it out of the way to narrow the frame the correct way, I am hoping when I am done you won't be able to tell I was there.
I will try to get pic's up soon, probably just wait til I have the rotors on.
