141 - 156 of 156 Posts
Discussion Starter · #141 ·
Well figured I would update this. Everything is complete and getting ready for Nationals, in the alignment shop right now, brakes seem great still breaking them in, so dont know for sure yet, but crossing fingers all is good
notice any pedal feel change before/after?
Discussion Starter · #144 ·
Well not much to be honest, about the same, the brakes before on my car were ridiculously good. I had to space the new master cylinder away from the pintle in the vacuum booster about 1/4 of an inch. The damn thing was sitting too far in and it was causing a residual pressure issue in the system and the car could stop with out using the pedal. All is good now, well seems to be, haven't had the chance to ring it out much, but pedal feel is good, not too stiff but just right. Alignment fixed alot of sh** tracks right now, put the new spacers on for the wheels this afternoon and damn looks just how I want it. I will post pics sooner, probably on the way to Nat's or something Thursday.
Discussion Starter · #148 ·
Without looking through this whole thread, I am pretty sure I showed pics of what I did. The rear bracket you have to buy from Kore 3, the backing plate is factory, but modified as stated above. What part aren't you sure about working on your car?
WOW! just buzzed over this whole thread, great stuff.... Thanks
Did I understand correctly that this set up will fit inside a stock wheel ?
Discussion Starter · #150 ·
Thank you sir.
No it will not fit in a factory wheel, minimum 18 inch wheel is needed. I may have confused it a little as I am using a factory vette wheel ;)
sorry
sorry it took so long but im looking for the front caliper brackit that go on the modded spindle ive been looking with no luck and i wanted the impala rims but if i have to go bigger i seen some look a likes 2 years ago that had the size 18 in so i hope i can go that route but would i have to get the brackits made thanks
Discussion Starter · #152 ·
No brackets you can get from Kore3.com you will have to call or email Tobin tell him what you are doing, the front brackets are located here. Front Bracket
I have a set in my shop that I can sell if you need them, they are brand new with hardware. You will need at least an 18 inch wheel to run these brakes, 17's won't cut it.
Look within here Front big brake kit
If you are piecing everything together like I did, you are going to need a hub, I recommend Kore3's obviously, as well as the rotor will have to be machined for a new bolt pattern and center bore. Most people find it easier to call Kore 3 lay down the credit card and have a complete kit shipped, I am hard headed I guess.
Brakes so big...
Damn man, those brakes are so big...your body would brake away from the frame if you had to lock um up. :eek:
Awesome job.
Back from the dead lol
Great thread Mike I will definitely have some questions for you when I get to my rear brakes this winter. I'll be installing 4 piston Camaro calipers.
