As long as wheel specs are the same on the new vette, you shouldn't have any problems at all. I like the first ones a lot. Be the first one with C6 rims on an Imp, but others will follow
Whooaaaa that pic of the black vet with the black wheels reminded me of Knight Rider!
Josh
The only problem I see is that the wheels are not the same size all around, as in close in diameter.
It will set an ABS light.
I just did the ZR-1 wheels, 17x9.5 and 17x11's and like the look.
How would 19x10's fit in the rear without some ceative modification? Would I have to measure the backspacing out on each side and order the spacer accordingly (sp?)?? These would look awsome on an Impala, and I think I would need a little bigger rim in the back since I just installed to Hotchkis springs!
Yeah, I've been considering a set of C6's myself (in black, of course). Definitely hot.
With 1.8" wide adapters, the 19x10's will fit in the rear without any clearance issues.
