K
Looking at my PST bushings, I see grease between the shell and bushing, can I assume there is grease between the sleeve and bushing?
If I dont have too, I'd rather not take them apart.
I
NO.. there is no grease between the bushing and the sleeve. You can revove it rather easily tho. Using a vise (open) or 2 pieces of wood, use a deep socket (slightly slimmer than the sleeve) and a hammer to push out the sleeve. Add grease and use hammer to tap the sleeve back in. I did it with all of them in about 10 minutes.
Don't be afraid to take it apart. It's just the sleeve, bushings and the shell. Nothing to it.
I took several of mine apart, and YES they were greased already....... After seeing that I left them alone and installed them as they were, gooping the stuff on the ends of the bushings during installation of the control arms..
2 weeks and no squeeks....
K
Just did mine. Didnt seem to have any grease on the sleeve, if they didnt, it wasnt obvious but seeing how easy it was, didnt hurt putting more.
