I need a good cam that could use with my 10309 crane springs and stock everything else does anyone know of one?
You should list what your current mods are and what your goals are for the car...just a cruiser, racer...nitrous, boost it....its what YOU want out of the car
Discussion Starter · #4 · (Edited)
Lol I guess tha would help
I have a cai PCM4less tune and 373 gears I want the car to be a good performing daily driver and lopie as possible with the springs and PCM I have (stock cam tune)
I'll get the PCM tuned again if needed
If you're staying with the stock torque converter, then the Crane 227 or a Comp 501 cam is as much as you will want. Neither of them will give much of a lope.
Change to a 3000 stall converter and go with a GM Hotcam if you want lope.
Discussion Starter · #6 · (Edited)
So what do I need to swap a 227 in it could I just get the cam and run it
Or do I need to change everything out and PCM tuned?
