Motor finally went in my 95 impala ss! Was going to rebuild until I found a complete lt1 out of a 94 buick roadmaster with only 120xxx miles! The question is..... is it a direct swap?? thanks seanj
should be a easy swap. wiring may be a little different if your 95 is ob2 and if the roadmaster doesn't have electric fans. if so u could use components from the 95ss engine to complete the job.
Your 95 is not OBD2.
1st consideration is tranny. Using the 94 that comes w/ the 94? No worries. Using the 94 LT1 w/ the 95 4l60e? Read. In that event, you'll need the 95 harness & PCM w/ the 94 LT1 or the 95 harness and the 94 PCM reprogrammed..
Have you the A.I.R. system still? Different check valves 94 to 95.
etc...
