I pulled my motor above 8 months ago for a rebuild and to replace pretty much everything
A month ago I had a bad seizure (grand mal) due to a brain tumor and 60-100 partial seizrues since then, My memory is slightly affected as a result so if anyone can help me so my buddy can put my motor and tranny in so I can as least make it run even tho I cannot drive for at least 6 months
He is going to do this in 3-4 weeks when my heads arrive as then i have everything
I need help with routing the PVC valve to the front of the intake anyone have a pic I got the fitting, a brand new 90 the metal pipe and the pcv what am i missing ????
I also need to know what to do with the breather?? that used to run from valve cover to TB, I am using the lt4 composite cover and no provision for the hose, should I cap off the TB
I bagged everything that was being reused and labeled them as well as pics but these 4 i dont see and the words came off the bags for some reason
I deleted the EGR the AIR switched to tri y gen 2 and ssri
so if its anything to do with that i dont need,
the one piece i know i used for engine removal but cant recall where it was
see pics below and pls identify for me and tell me a location please
