My driver's side door panel looks great on the outside but it doesn't like to stay attached to the door anymore. The little plastic parts that the clips attach to have cracked and are broken. I pulled the panel off last week and glued then JB Welded everything back on. It only lasted a week.
I need a new panel. Does anyone know if we can still get a new OEM or does any aftermarket company make door panels for a Raodmaster? It is different from the Impala panels. I can post pics if you need.
i bandaid my problem by using two washers on each screw holding in the door panels. one large one to hold the plastic to the door and a smaller washer to hold the larger washer in place. same with the rubber arm rest.
