IMPALA 94-96
Constant 12V+ Red Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Ignition 2 BROWN Ignition Switch Harness, (check engine light)
Accessory Orange Ignition Switch Harness
Tach Red/Black Or Pink/Black (-) at Multi Coil Pack
Neutral Safety Wire Orange/Black Gear Select Switch
Brake Switch White Brake Switch
Trunk Release Black/White Switch
Trunk Pin Dark Green (-) Driver's Kick Panel (Rear Body Harness) (96)
Parking Lights Brown Light Switch
Head Lamp Yellow Light Switch
Door Trigger White (-) Driver's Pin Switch
Door Lock Light Blue Behind Driver's Kick Panel
Door Unlock White Positive Trigger
Horn Wire Black (-) Steering Column
CAPRICE
Tach White Or Purple/White (-) At Coil V8 or Multi Coil V6
Trunk Release Black Switch
Door Trigger Blue/White (-) Driver's Pin Switch
good info Cough(the12volt.com) but you should put the VATS wires in there too
is its me or are thoes wire colors a lil off from mine beeing a 95 9c1
Well here then, little easier to look at a drawing than typed information :) I drew this up sometime ago for a member that was doing a Viper 5901 or something similar, should be close across the board.
Let me know if this works for you
http://www.impalassforum.com/vBulletin/showthread.php?p=2449009#post2449009
This diagram is the **** much credit to him for the time
I will add to those wanting the newest LED LCD models like 5906 the
Door lock unlock output on the alarm has kept up with the times and is a positive output only if you want to use this alarm u must use 2 relays one for lock one for unlock if you need the wiring I can send it to you or use a 451m door lock module one will control all 4 doors again if you want I can send it I will post a copy of that here soon as well as the wiring codes for the new vipers
