H
I have a 10 bolt rear and got some Richmond Gears with a Powertax Locker and in need of a reluctor, can anyone provide some info on a reluctor for the Caprice
A
Return the gears (sure hope you can!). None of the Richmond Gears have any provisions for the ABS reluctor on the pinion, and thus you'll lose your ABS.
Go instead with the GM gears from one of the vendors on this site, and get the GM ABS reluctor (PN depends on the gear ratio).
Yeah, what Ed said! :D
Plus Richmond Gears are notoriously noisy. What gear ratio did you get? Once you get the setup straight, post your opinion of the PowerTrax, please.
Reluctors are available for most gear sets from a variety of vendors, including the Superstore and Dal, as well as your local dealer.
