·Ok, I did the 9C1 bushings in January I think, and put on the HD (0929/1104) Bilsteins about a month ago. Now it just seems to be getting worse and worse. As the car goes over bumps, it usually dives toward the pass side, and shudders really bad. The car does lean to the pass side a bit too, but mostly to the front corner.
It is a salvage vehicle too, and I have suspected a bent fram for a while now...I don't know if bad upper body bushings would cause this too, but some of them did look pretty bad, and after install and torque, some lowers didn't touch the frame.
My next project will be the steering/suspension but I don't know if I should do bushings too, or just tie-rods, bj's, and what not, or if there is something else which might cause the car to act this way. Thanks to all in advance.
-Jeremy
-Jeremy
