1 - 9 of 9 Posts
My '95 wagon is still pulling to right even after an alignment. At low speeds, the car tracks pretty straight. But once I pick up speed and hit about 60-65 mph my car starts to pull hard to the right, and I have to keep the wheel at 11 o'clock in order to keep it straight. I'm getting vibration in the steering wheel at high speed also.
Your alignment was done improperly. Where did you take it? I suggest you take it to a shop that specializes in alignments. Do you have the alignment printout?
I didn't get a print out, but I gave them the "improved" B-body alignment specs that have been floating around the site. I live in MD, I couldn't find a shop that specializes in only alignments. The car drives a lot better, and the steering is more responsive, the pull and the vibration are the only issues. What should I look for or tell them to do when I take it back?
Your best bet is to contact a decent body shop and find out who does their subbed frame & alignment work. It won't be Midas or some chain store. There are plenty of those businesses in MD.
I would rather take it back to the shop I already paid, before spending more money at another shop. I at least want them to try and correct the problem first.
Swap the front wheels. If the pull goes the other direction, you've got bad tires.
That was the first thing I tried, no change.
They didn't leave something loose did they? The morons that did my sedans alignment left EVERYTHING they touched loose.
Discussion Starter · #8 · (Edited)
When I got under there and checked, everything was tight.
But, one thing that's been driving me crazy is ever since I changed my front shocks I have have been feeling like a "tap, tap" when going over bumps. I keep thinking something is loose somewhere, but I don't see anything. I can feel it in the pedal every time I hit a decent bump.
Have them check the condition of your ball joints and idler arm. You may have excessive play.
For the shocks check the Top bushing and washers. I had something similar with my car. the upper shock washer was hittin my control arm causing a squeaking or tap tap noise.
1 - 9 of 9 Posts
