I was wondering if anyone could help me with a CB issue I am having. The CB works ok in the car but not when the car is running. When I turn it on the level meter hits the top and it's all white noise from there. Also, when I rev the car up you can hear the whine get louder as the car idles faster. This CB works fine in every other car I have had it in. It also works ok in a 9C1 that my brother had. I am running it in a 96 SS. It is connected through the Cig lighter for power. I don't believe the car has resistor plugs. Are there any measures that I should take to make the noise go away that is caused by the car being on?
Thanks in advance, MrMaJ
Just for giggles I would run a seperate ground to the unit.
Peter
Thanks for the advice. I will have to try that. Anyone else have any suggestions?
