I finally got around to de-screening the MAF on my 96 BBB. I was rewarded with a CEL when I restarted the engine. I disconnected the negative battery terminal for a couple hours hoping it would re-set. It does not appear that this has worked. I thought I read once that it would take the OBD II a couple days of driving to notice the increased flow and the CEL would go out. Is this wrong or do I likely have an air leak in my re-connections. I have the Gen II FIPK from K&N installed for four years now with never a CEL. Any advice?? thanks chydog :confused:
I think the connection to MAF is not correct or poss "air leak", should be no CEL at all, recheck connections, vaccum hookups, wires, etc.,... :D :cool:
<BLOCKQUOTE>quote:</font><HR>Originally posted by Jeff in Western WA:
I think the connection to MAF is not correct<HR></BLOCKQUOTE>
Sure you didn't put the MAF in ...backwards
:eek: ??
Hey...sh!t happens :rolleyes: .
KW
After I descreened my MAF I ran .8 slower than before. 15.6 @ 88 mph. Turns out I put the damn thing on backwards like KWbaraka said. So sh!t does happen :confused:
Thanks all, a little embarrassment. MAF was put in properly however I must have had a leak in the connections. Re-aasembled and CEL is gone. Haste makes waste 'eh. Next time i'll double check before i use my lifelines. Thanx chydog
I de-screened my MAF, no lights. Low speed stumble, surging, not happy. Put the screen back on and everything smoothed out. Don't go to the track so I don't know the difference there. But street driveability is much better for me with the screen in place. Has anyone else had similar experiences?
<BLOCKQUOTE>quote:</font><HR>Originally posted by 95LTZ:
I de-screened my MAF, no lights. Low speed stumble, surging, not happy. Put the screen back on and everything smoothed out. <HR></BLOCKQUOTE>
Don't muck around with precision measuring devices.
AFAIK removing the screen if your intake has bends (like the stock system or an FIPK) may cause issues.... while using a straight-into-the-TB intake like a RAISS or SSRI allows for problem-free screen removal.
