F
I messed up the threads on one of the center link studs (dont ask :( ), now when I try to tighten the castle bolt, the whole stud just spins. Can this stud be replaced? I've searched and I've found people with similar problems (stud spinning) but I havent found a solution. New centerlink?
A
Try retapping the threads on the stud....if that won't work, then you're probably looking at a new centerlink.
I
have someone with a pair of channellocks ,squeeze the 2 togeather so the the taper is forced into the hole sometimes thats how i have to do it to kep em from spinning
F
got a new centerlink, all is well again! thanks guys!
