·i'm currently running acdelco ceramic pads on the front brakes, along with powerslot rotors, and pf pads and powerslot rotors on the rear, i have approx 4000 miles on the pads, and recently noticed a strong shuddering coming from the front as i brake on a down hill decline.. this happens at partial pressure on the pedal & also full pressure on the pedal, also installed a stealth bolt..i did not replace the seals when the new pads went on...is this common with ceramic pads or is the problem somewhere else..already wrecked one beast, and can't afford to wreck another
