I signed on to the forum years ago (2004). My 95 DCM is stock and had I had hopes of building it after putting 5 kids through college. If there was any money left. I have one more kid with one more year. Unless he goes to grad school.
Sadly, I was out of state for years and my family left the car outside, uncovered. The paint and rubber is a wreck.
But still I have hope. Probably just build it to a nice driver.
So it has 151K miles. Changed Spark Plugs this weekend.
I had checked wires for 2 nights before the plug swap and saw no arcing.
Only thing recently changed were the plugs. I just used the Autolite 104's.
I wasn't sure the car was going to pass smog this year so cheaped out on plugs. Probably not the best idea.
The engine ran great for a few spirited run through the streets. On the freeway she pulled well.
But on the way to gas up it started to stumble at the off ramp light.
I headed straight home so I didn't stall on the street that night.
I checked today. Started up OK and rev fine. Then as it sat there idling it started to have a rough idle.
I checked exhaust while revving and at idle. No smoke. I saw wet spray on the pavement behind exhaust pipes. I figure condensation from better combustion. Before changing plugs the exhaust was dry and rich smelling. Then I noticed the Right Exhaust bank (dual exhaust) is where the miss is coming from. Irregular miss. No backfires.
Maintenance History:
I had the OPTI & Water Pump changed at 125K miles
O2 sensors changed at 130K miles
Spark Plugs at 151K miles which is current mileage.
I've seen some posts similar to this. So many possibilities.
I tried to think what I may have done. Don't think I cross threaded any plugs.
Possible issues:
1. I haven't checked the rear driver side plug wire because I couldn't get to it yet. Gotta lift the car. But it should be fine. I double checked it the first time I put the wire back on. When I can jack the car up again I will recheck wire connection.
2. Didn't have dielectric grease handy, but had plumbers grease so used that on the plug.
3. When I was trying to pull the wire from the Left rear spark plug I was reaching down there with a wrapped plier and I think when I was pulling on the plug wire I was actually pulling on the knock sensor wire. A cloth was covering the plug and sensor wire so I can't say for sure but I think the first time I was pulling on the sensor. So maybe something is up with the sensor. I think it's the knock sensor. And on the driver side the plug on that sensor just spins around.
That doesn't seem normal.
Sad to say that I tried to do this simple job and made things worse. At least before this swap the engine ran good but had poor gas mileage (14 mpg). But that's kind of normal for these cars. Now it's idle is not so great.
So any leads on those 3 possible issues. Or any more thoughts.
My back is pretty wrecked lately so I may have to opt to go to a shop. So anyone in the San Diego area, near Poway, have a good Impala expert, please send me their info. I am also willing to drive.
I used to drive all the way North to George Bates' in Upland, CA to get the car worked on but he no longer has that business. I don't suppose Angel who took over from George is still running it now. However, I don't know about driving that far with the engine acting up as it is.
Possible issues:
