just looked at my '95 roadmaster trans fluid plumbing and it doesn't have the clamp on line up front by the radiator like the SS or the 9C1 that is used by many to drain the trans fluid. all the connections are threaded. anyone encountered this before and have solution?
I'm thinking I could just cut the rubber hose line and do the the fluid draining then reconnect with a brass barbed hose connector and clamps. any thoughts on that?
Super Moderator
I've done it that way on other cars. You're not the first to encounter this on a B-car. Other option is to just unscrew a line from somewhere and don't cut it at all.
