1 - 10 of 10 Posts
ok so i just got in my car and the check engine light just popped up and it was driving fine all morning and just like normal and once the light came on it is super sluggish and is like stuck in 3rd or 4th gear. it takes forever to get up to speed but when im going about forty or so it has power. in park in revs fine and hard just when itake off its like stuck in a high gear.
ps. its a 95 9c1
You need to pull the code before anyone can give an idea of what might be wrong. There are lots of discussions here about how to do that.
You can get the codes read for FREE at Pep Boys, or most equivalent auto part stores. Or you can buy the software, cable, and laptop.
ok ill do that. since its a 95 is it obd1.5? and will it plug in and read or do i have to use the jumper method?
auto stores dont check the codes on obd1 anymore
You must get codes read... NO jumper method available !
1 - 10 of 10 Posts
