·Just wanted to post a reminder to check those bolts regularly on the aftermarket sway bars. Last night while under the car, I found three of the bolts loose enough to turn by hand. That Herb Adams bar works a lot better when the bolts are torqued propperly.
1996 Impala SS
3.73 gears, Dynotech DS, S-10 TC, FLP headers, SLP exaust, GMPP 1.6 RR's with Crane springs, F-Body MAF, HPP3 w/o tuning, LT4 ESC, Fairbanks HD servo, Amsoil tranny fluid, TB bypass, air foil, sewer pipe intake w/ 1LE elbow, Moroso Blue Max ignition wires, Accell shorty platinum spark plugs, Herb Adams front and rear, Hotchkis uppers and lowers, Eibach springs, ES body mounts, larger 5/8" ball joints, ES front control arm bushings, Buick steering damper, Russel braided brake lines, combi brake mod, PF brake pads
1996 Impala SS
