Not much info. Idle is controlled by the IAC. Maybe it's bad. I've also seen a faulty (low temp) coolant temp sensor cause odd idle (car thinks it's -34 degrees out and tries to compensate). Vacuum leak around the intake can cause odd idling. But the list goes on and on. Fuel pressure, injectors, etc. Good luck.
