Is 4.30 available for the GM 8.5" rear end? I know about 4.10 & 4.56.... best is the T56 with 4.10.
Don't forget that back then converters did not lock up.How times have changed
In the "olden days"
highway speeds were typically 70- 75 mph , highway gears were 2.73-3.08 and
high gear was 1-1
I don't see how they'd know what they were missing? Much easier to put too steep a gear in and say "man, I miss turning lower RPM's on the highway" than put too shallow a gear in and imagine the car might be faster? by what, a tenth or two at best? Just seems like a pick your poison thing to me.The difference isn't much either way, in performance or highway RPM, so it really just comes down to which you value more and how/where you drive.Far more folks with 3.42's wish they'd gone with 3.73's than the other way around.
Same with 12" vs. 9.5" converters.
From my admittedly faltering memory of his website:RJI said:My car came with 2.93. I went with 3.42, then 3.73.
I tested performance and economy of all in real world testing and have settled with 3.42 for my style of driving.
The car felt best with 3.73 around town
but 1/4 mile times were no better than with 3.42.
The deciding factor was gas mileage. 3.73 ate much more gas than the 3.42.
Any LT1 B- or D-car with 3.73 and no other mods (except maybe a speedo correction?) will get much closer to 154MpH, than any LT1 B- or D-car with 2.56 or 2.93.You want pussification, get a Caprice with the pussified gears.
Do you have a little list that i can go off of? I know i need KDS mounts, LS1 oil pan, a better trans crossmember, measure for new driveshaft, ls1/6 intake, fuel system updated for corvette filter with built in regulator and do A/N lines for that, and a wiring harness. I think ultimately its the better platform to go with for better power and gas mileage when not stomping on it. Thank you so muchYup and yup see sig.
If you are going for a proper job , the money goes pretty fast . And for me it was all parts
Mine also has crazy exhaust leaks that drive me crazy. Doesn't throw codes anymore since hooking up EGR correctly. Maybe my trip meter is lying to me one second i saw it over 170 miles then the next it was slightly lower at 168.Skip the vette regulator and go ahead and get an aftermarket one
Also that is crazy you are only getting 7 MPG. Even my massive exhaust leak, code throwing LT1 got 17 to the gallon around town
