If all that is out and the fuse is good, I would be leaning toward a bad ground. Check the connections behind the kick panel and may as well clean them up while you're there.
http://www.goldsswagon.com/diagrams/impala_intrument_illumination.pdf
This area is known to cause issues with electrical stuff in the car and is easy enough to check.
The same fuse operates a lot of other lights as well. If those are the only items not lit, then it is a ground, or splice. If your car is a Caprice, it may be the dimmer switch for the cabin. Your ashtray lamp is also controlled by the same circuit.
