1 - 20 of 36 Posts
A
Read on, and use it as a learning experience. I know I will
So, I had run out over lunch hour today to "swap out" cars and get my SS for the ROD South Bay meeting tonight. Gunned it a bit on the way back to work.....nothing major, just having fun around a few corners (the car is on the autocross tires right now).
At 6:45, head out the door for the short drive to Bennigan's for the meeting (it is about 5 minutes from work). Get a half mile from work, around the first right hand sweeper on Duane Ave going towards Lawrence and.....
BAM
...right front of the car collapsed off the lower balljoint! Fortunately only doing about 25 MPH at the time, managed to limp it over to the curb despite the wheel completely locking up as it got shoved into the inner fender and the wheel wedged itself against the lower control arm. LOTS of tire smoke, and the right front frame is now about 1" off the ground. And left some nice scrape marks on the road too
Fortunately, Trevor Gould was able to come over to where I was on the side of the road with some floorjacks and basic tools. I also looked on the road where it broke and much to my surprise quickly found the lower balljoint castle nut.....WITHOUT a piece of stud in it?!?!?!? HUH??
Turns out what had happened is that the balljoint did NOT break (which is what has happened 99% of the time that you get the symptoms I did). Rather, the cotter pin had broken on the balljoint at some point (found remnants of the pin inside the hole thru the joint) and the nut had slowly been backing off. Once it got down to the last 2 threads, it let go when I went around a right hander that let the balljoint "come loose".
The threads on the balljoint were not buggered up, although the nut sure was!
I had THOUGHT the right front of the car looked slightly low lately, but had just assumed I was parked on a slope and/or was being paranoid (which happens when you have recently changed as much crap on the car as I have changed in the last few months).
After a parts store run (and finding out they didn't have the right nut in a castle-nut), Trevor got a pair of Grade 8 regular nuts of proper size. Installed the first nut and torqued it down, then put on the second nut as a backing nut (also torqueing it down against the first nut). Got it back together enough to carefully drive the car back to work (it felt fine) and park it.
Final KNOWN damage : </font>
  • Buggered up the inside of the Forgeline wheel. It should be fixable, and the tire is holding air just fine.</font>
  • Flat-spotted a Kumho VictoRacer tire......should be OK, but it'll "thump" for a while
    </font>
  • Scraped up the powdercoated inner fender in one spot....it'll live
    </font>
  • Scraped up lower control arm.</font>
  • Obviously, the lower balljoint is short for this world
    </font>
UNKNOWN :</font>
  • any other damage to the control arm.</font>
  • Any damage to the shock bottom mount.</font>
  • Any damage to the spindle, especially if it has been moving around for a "while" on that lower balljoint.</font>
Now for the ironic part : I not only have 2 NEW AC Delco lower balljoints at home in packages, but also just YESTERDAY I had ordered the entire new "Enhanced" front end kit (tierod ends, centerlink, idler, and BALLJOINTS) from Power Performance off the this Forum. I was planning on swapping out all of this stuff next week anyways!
For now, I'll limp the car home on side streets (5 miles) and go from there. Also doing a "secret" new upgrade with the new parts in front that no-one else has done before.....I'll unveil it if it works
J
and you said you were going to install rustic's tubular a-arms. i bought them monday. you were real lucky
L
Dang, Ed! But you forgot to add to your "known damage" list: brown stain in center of driver's seat.
Glad to hear that nothing more serious came out of this. Be careful out there.
W
Damn, Ed. I'm glad you're ok ! I've heard some REALLY evil stories of the lower ball joint breaking at much higher speeds, it's all you can do to keep the painted side up if that happens.
I get paraniod too when I think my car is tilting to one side or the other, I'll pay even more attention now !
Ed
Glad to hear the damage was light. Good thing it did not happen at speed on 101! I should have come to the meeting last night. :(
Milt
Ed, thats terrible. I am glad you did not do more damage that you did. I for one am going to double check all my ball joints next time I have my cars up in the air.
A
Milt : don't worry, you were next on the "call" list to bring some tools/jacks if Trevor hadn't been home ;) . BTW, you can easily see the scrape marks on the Duane Ave from my incident last night......call it marking my territory
Terry : fortunately, the NEW leather upholstery (I redid the seats front and rear 2 months ago.....since you drove the car earlier this year) is still clean
A
Ed: Glad you OK and car seems to be mostly good too. Very fortunate it wasn't at high speed. Going out to garage tonight and check all my cotter pins.
L
Damn Ed,
Glad to hear everthing worked out,
Glass is half full..
Now the question I have, Is what kind of Cotter Keys you have been using?,, theoreticly there should be NO WAY a castelataed nut can overcome a Cotter Key. I know a lot of the vehicle parts suppliers, supply zinc coated steel cotter pins and they should be strong enough, but I have a large supply of Mil Spec Stainless keys that I use..
If I was a suspicious individual Ed, I would think your BJ Nut had some help overcoming the cotter Pin :(
A
Mike : they were some cotter pins we had lying around that we threw in there when we pulled apart the suspension about 12-13 months ago to cut the front GW springs slightly (1/3 coil). Unfortunately, I don't know what they are from or what they are made of.....but they were new/unused cotter pins at that time. Other than an alignment right after that (by a shop that I trust 100%), no one has touched the front suspension since then except for me.
The castle nut that I found on the road showed signs that it had backed off. Namely, the threads inside the nut were OK until the last 2 threads, which were buggered up. It sppeared to have backed off until 2 threads were holding the nut on and then BAM....gone at once. Threads on the balljoint are perfect, not buggered at all.
I am starting to wonder though if the spindle wasn't completely seated on the balljoint and thus had some slop in there it shouldn't have. I also am wondering just how long the cotter pin had been gone! It should go unsaid that I'm gonna be looking pretty carefully at the lower balljoint taper on the spindle before I reassemble everything!
F
Ed,
Close call...glad to hear that you're OK, and more importantly, your car came out alive ;) :D
H
Discussion Starter #13
Sorry to hear of your TROUBLE and thank the big guy above for that one! Now get that baby back together and do some AUTOCROSSIN!
WHEW!!!
Discussion Starter #14
ED's car needs prayer..
at least you are ok, i can not imagine that happening on the freeway.
Discussion Starter #15
Ed, wow you really had a close call. Luckily no one got hurt.
I figured out your "secret" new upgrade. You are going to put hydraulics on your SS so next time something like this happens you can do this all the way home.
Discussion Starter #16
Three wheel all the way home.
I used to hang with some guys into switches. One day, a Cutlass busted an A-Arm from hopping. He didnt call a tow truck. 3 wheeled it all the way home!
A
Discussion Starter #17
LMAO at da 3 wheel motion :D :D
BTW, sonuvah posted on the ROD list this morning that he ALSO found the cotter pin on a lower balljoint sheared off on HIS car recently (on balljoints that were only a few weeks old). Fortunately for him, he caught it with the nut still holding on by a few threads.
He re-pinned it with stronger cotter pins, seems OK now.
A
Discussion Starter #18
Got about 30 seconds (no joke) of free time over lunch hour to look under the car today.
The right HAL shock is toast, as about 1/2 of the mounting bushing holder is GONE. And the mounting bolt heads are 75% sheared off.
Arm is scraped up a bit, but will live
Other than that, remarkably that is the only thing underside that scraped. Other than the inside of the wheel on the lower control arm, of course
P
Discussion Starter #19
Ed,
Sorry to hear about your mishap. I'm going through the same thing right now.
I broke a drivers side lower ball joint last saturday. It damaged my rim, shock, front bumper cover, front fender, tie rod, adjuster sleeve, wrecked my tire and I am not sure what else. I have replaced the ball joint and am in the process of replacing the steering parts.
I just picked my rim up from getting repaired. They had to weld a cut from the edge of the rim into the bead and fill a couple gouges out of the inside. I was suprised how good it turned out.
My car ended up right on the frame and the tire went up and bulged the front fender out. I have to take it to the body shop next week to see what can be fixed.
Later,
Brad
Discussion Starter #20
What brand cotter pins did Sonuva go with? Just wondering as I am going to be putting my front end together tomorrow after the required 185k mile rebuild.
1 - 20 of 36 Posts
