EVAP switch
EDIT: I had a code p0441, it was fixed by a incorrectly connect hose. Now the car throws a P1441.
I have the same code (p1441) on my 96. Can anyone tell me if the EVAP purge vacuum switch is typically open or closed when not powered?
The book says "the switch should be closed to ground with no vacuum present... " Im not exactly sure what that means. I can blow through it without resistance, does that mean its bad and needs to be replaced? I already replaced the solenoid because I could blow through it, not sure if it was bad, but the new ones i could not blow through.
I already checked all the lines, they seemed good. Only a few very small black specs came out. When I removed the line from the top gastank, it started hissing and relieving tank pressure, so I know it doesn't have a hole in it. I'm guessing the gascap is good as well, as it hisses and relieves pressure when I loosen it too.
Thanks, for any help that can be provided. I hope I can get it fixed soon, as it has to be before I can get a smog certificate.
