Hello everyone,
So I saved enough money to upgrade my suspension on my stock 1996 Impala, sparing no expense with the best performance parts out there. My set-up plan is to keep it stock aside from the suspension and drive it on the weekends only, but I want to maximize (with stock seatbelt) the driving response on cutting the corners without wearing a seat belt harness.
Option 1
- QA1 Level 1 with QA1 Sway & Upper/Lower Control arms
If anyone is running this set up, let me know if you have any regrets?
My original plan was option 1, but if there is a better performance set-up out there that's recommended, then i don't mind mix matching (a la carte - Option 2) with any of the brands below:
Option 2
Coil Overs:
Sway Bars:
Rear Upper & Lower Control Arms"
Any input from my fellow experts would be greatly appreciated before I pull the trigger.
Salutations.
Chavo96
Option 1
Option 2
Coil Overs:
- Speed Tech
- QA1
- Am I missing one?
Sway Bars:
- BMR
- Hotchkis
- UMI Performance
- METCO
- SpeedTech
- PMT Fabrications
- BellTech
- Eibach
- BMR
- Hotchkis
- UMI Performance
- METCO
- SpeedTech
- PMT Fabrications
Salutations.
Chavo96
