Anybody have the tire size on the compact spare? I'd like to see if I can stuff the spare in the side of the trunk... hmmm
145 80 16 - off the top of my head? Something close to that... I will go google...
Can't find it. I don't think it will go in the side (vertical). They are great, though. Small, and dual 4.75/5 bolt pattern. Just remember not to use them on the rear axle! Swap the front to rear, and run the spare up front. Your posi will thank you.
Originally posted by jayoldschool:
145 80 16 .....Just remember not to use them on the rear axle! Swap the front to rear, and run the spare up front. Your posi will thank you.
I don't have a space-saver......but those numbers look right. It's one of the 'standard' GM space savers.....that's why the duel bolt patterns.
And definately don't put it on the rear.....if you can locate one!
KW
I was just outside doing some work in the back of the wagon. The size I have above is correct.
Jason.
