I am trying to get my daughter car running her sorry excuse of a baby daddy left her high and dry with their autistic child when you actually get power to the car the interior lights an fan blower will not turn off help me please
This forum's knowledge base is in 1991-1996 b body rear wheel drive cars.
Please specify what car, Impala, Caprice, Roadmaster, or Fleetwood and the year?
I do not understand what you mean.
Does this happen any time the battery is connected?
Does this happen only when the engine is running or when the key is out?
If you have a much newer Impala try:
i ahve a 96 impala ss and have a few parts i am looking for are there any US comapnies that make remanufactured or similar parts
driver seat rocks a bit needs either new insert from alibababa or new seat rails
window driver side has issue with broken plastic socket for window actuator
other then that that is all for this car before we can start cleaning it up properly
please let em know if you can help
You can check the vendor section for the seat parts. They are a little pricey, but available.
Depending on what "socket" you are referring to, you may be in luck. The window sliders are available from Rock Auto, although you need to buy the "rollers" instead of the sliders. If it is electrical, used parts are your source.
