I did a few searches about the LTCC on here and didn't see how to connect a tach to this system. Just doing some research. Thanks.
You can connect your tach directly to the PCM if you want, it's pretty easy once you know where to connect it cwm5
Tach output is pin A13.
http://shbox.com/1/1995_pcm4.jpg
http://shbox.com/1/1995_pcm_conn_a.jpg
We dont have a wire at A13, so you'll need to buy a connector "pin" that goes there from the dealer and then that will be your tach signal source.
Hope this helps.
BTW, do you have the instructions for your LTCC?? I cant find mine and I'm looking for the part that explains what the DIP switches and dials do.
