This is something I've been pondering for a while, and I keep wanting to forget it, but it keeps nagging at me.
I have a complete Fays 2 watts link setup in my garage. It's intended for 2nd gen F-bodies, but I decided to stick with leaf springs on mine, so it's useless to me. It just sits there, taunting me...
Our B-bodies use a triangulated 4-link setup, which also doesn't lend itself very well to a Watts link (dueling roll centers and all that). That 4-link setup is comprised of weak, flexy bits and soft rubber bushings which don't do the best job of locating the axle laterally, but they need to be flexy and soft to accommodate the geometry. It's all very frustrating.
Then I remembered that B-bodies used to come with a 3-link setup, once upon a time. And those cars used a panhard bar to locate the axle laterally. In fact, UMI sells aftermarket top links and brackets for those cars:
www.umiperformance.com
So if I converted the rear suspension to a 3-link setup using those bits, then a watts link suddenly makes sense. I can use it to set my own roll center, and the axle would remain perfectly centered all the time without any binding.
As far as I can tell, the only thing I would need to do this is bolt a bracket to the frame crossmember, and weld a bracket to one of the axle tubes (the 3rd link doesn't need to be centered, and historically hasn't been). The only real complication I see is finding room between the rear end and the gas tank to accommodate a watts link. I suppose I should probably also weld the axle tubes to the center section if the top link will be acting on a tube.
I dunno, it seems so simple, surely I must be missing something?
1959-1964 GM B-Body Adjustable Upper Control/Trailing Arm- "Banana Arm" - UMI Performance Inc.
UMI Performance offers one of the only on-car adjustable control arms for the rear of the GM B-Body vehicle. This
