Part 1: get all the parts + test-fit.
I flush, I backflush, and I can’t get the [email protected]# knock sensors out. I know I need to get someone to remove them to flush out the settled crud in the block, but a coolant filter will be a fun experiment anyway. Thanks to this old Smelonas thread for the location idea: A coolant filter how to...
Two short hoses will tee into the heater hoses in front, sammiching the radiator hose but not blocking or interfering with anything. Careful connector lengths will keep the heater hoses off the belt-drive.
Parts:
--ACDelco coolant filter base 25010047, cast aluminum, same as Baldwin CFB5000 (no AC logo). New ones are from China. Found this Michigan-made NOS one on Ebay for less than the new ones. Should be plenty of them in junkyards, too. Right now I’ve got the extra ports plugged, but it would be convenient for a low pressure sensor (like you might want with an EWP).
--Wix 524069 filter, no chemical additives, made in NC. It’s the shorter version of Napa 4070.
--MidAmerica NPT 3/8-18 fittings, made in US
29ESB-86 single male hose barb for half-inch ID hose
2945-86 elbow for half-inch ID hose
29AL-6 countersunk plug (2)
--Four Seasons 84543 5/8 x 1/2 x 5/8 metal heater hose 90-degree tees (2).
Y fittings would improve flow through the filter, but I haven’t found metal Ys in the right size yet, only plastic (like Kat 28111, available many places). I trust metal more.
--Gates 28410 half-inch ID heater hose, 2 feet.
--Heat-shrink hose clamps—new for me. Clean look and easy.
Gates PowerGrip32925 for hose w/ OD min. 15/16” (need 4 for the 5/8 ID heater hoses)
32922 fits 13/16 to 15/16 OD hose (used 4 for the 5/8 ID heater hoses on the tees, and 4 for the 1/2 ID filter hoses. A filter hose with a wall any thinner than the Gates 28410 would need a smaller shrink clamp.)
--Two 3/8” bolts and nylock nuts to mount the filter base. I bought 1.25 inch ones and cut them down flush with the nuts. Nothing hits the radiator.
--The filter assembly is almost 3 pounds without hoses and coolant, so I used a piece of 3/4 x 3/4 x 1/16 aluminum angle to reinforce the plastic radiator cover, plus two #8 x 3/4 panhead screws, washers, and lock nuts. Trimmed bolts after assembly.
Next step: To restrict flexing/vibration, make a support bracket from the filter mount down to somewhere on the fan bracket. After that, backflush the heater core and splice in the filter. More pics as it comes together, and then I’ll put some miles on and see what gets filtered out.
Parts:
Gates PowerGrip
